Updating the firmware on your dash cam will keep your camera working at its best. By following the right steps, you can add new features, prevent problems, and keep your camera running smoothly on the road. This complete guide explains everything you need to know about how to update dash cam firmware.
Certain clues tell you when your dash cam is ready for a firmware update.
When you notice any of these problems with your dashcam, your software might be out of date.
NOTE: If your dash cam is working properly, we generally do not recommend updating the firmware just for the sake of updating. Installing the wrong firmware (or an update that isn't intended for your exact model or hardware revision) can cause malfunctions and, in rare cases, may even prevent the camera from powering on. Always confirm compatibility and follow the manufacturer's official instructions before you update.
Your next step is to decide which update path matches your dash cam.
Knowing which way to update your camera can help you avoid making mistakes.
Preparing well helps you avoid problems during a firmware update with your dash cam.
First, confirm your dash cam's exact model (and hardware revision, if applicable). Then open the "System Info," "About," or "Version" screen in the camera menu to find your current firmware version. Compare it with the latest version listed on the manufacturer's official support page.
Before updating, make sure to back up any important videos from your memory card to your computer or phone.
While a firmware update doesn't always require formatting, many dash cam manufacturers recommend formatting the memory card after the update. This helps prevent potential issues such as recording errors, file corruption, or system instability caused by outdated file structures.
To ensure the best performance, it's recommended to format the memory card directly in the dash cam after the update. This gives the device a clean start and helps avoid unexpected problems during recording.
A fast and reliable microSD card reduces errors during the update. Cheap or faulty memory cards may stop updating or damage your camera. Before you start, make sure the card isn't full or broken and stick with brands you know and trust.
Before updating, it's best to keep your dash cam plugged into a stable power source or make sure it's fully charged. If your camera dies while the update is going on, it might not turn back on.
Always download firmware from the manufacturer's official website or official support channel. Avoid third‑party files from forums or random download sites—using the wrong firmware can cause update failures or even brick the device. For example, WOLFBOX provides official downloads here: WOLFBOX firmware page.
A lot of users update their dash cam firmware using a microSD card because it's quick and easy.
Visit the official website and look for the firmware that works with your dash cam model. Download the right file to your computer.
You can update the firmware wirelessly on some models by using your smartphone and the official app.
Launch the official dashcam app on your phone. While the camera is on, make sure your phone can connect to its Wi-Fi signal.
Some dash cam models require a computer-based update. In this case, you'll connect the camera to your computer with a data cable and use the manufacturer's official desktop update tool to install the firmware.
Sometimes a firmware update doesn't work on the first try.
If your dash cam doesn't start the update, check to see if the firmware file is in the root folder on your memory card and not in any other folders. This direct placement makes it easy for your camera to find the file when it turns on.
If you get an error that says "invalid file" or "version mismatch," you probably downloaded the wrong firmware for your dash cam. Go back to the website, check your model again, and download the right firmware.
Your firmware file may have been damaged while you were downloading or transferring it if your camera gets stuck or keeps restarting. Reformat your memory card, download a new copy of the firmware from the website, and try updating it again.
Sometimes, firmware updates don't work because the memory cards are too slow or old. To help your dash cam read files quickly and avoid problems, use a fast, reliable card that is often called Class 10. If you're experiencing persistent issues, you can check this detailed guide on SD Card Not Working in Dash Cam to troubleshoot common problems.
If you lose power in the middle of the update, it could stop it and make it hard for your camera to turn back on. Connect your dash cam to a steady power source, insert the memory card, and then try holding down the power button or following the reset steps in the instructions.
If you've tried the troubleshooting steps and the update still won't complete, it's best to contact the support team. Share your exact dash cam model, your current firmware version, the firmware file (or version) you attempted to install, and any error messages or symptoms you're seeing. With those details, support can guide you through the correct recovery steps—or provide the right firmware package if needed.
It is easy to check if your dash cam update worked.
Feature To Test
Expected Result
Action If Failed
Version Number
Matches new download
Repeat the update process
Video Capture
Clear and smooth playback
Reformat the memory card, try again
Mobile App Link
Connects without errors
Reconnect Wi-Fi, restart the app
Keeping your dash cam firmware up to date can improve stability, fix bugs, and unlock new features—so your camera stays reliable when you need the footage most. You don't have to be a tech expert; just check for updates occasionally, follow the correct method for your model, and stick to official files and instructions.
If you're using a reliable dash cam brand like WOLFBOX, you'll typically find clear update instructions and support resources to guide you through the process.
Check your current firmware version in the dash cam's settings, then compare it with the latest version on the manufacturer's official support page. Update if you're experiencing bugs or if the manufacturer recommends it for your model.
A firmware update may fix bugs, improve stability, enhance video performance, and add or refine features such as Wi‑Fi/app connectivity, GPS logging, or parking recording options.
Possibly. Some updates require formatting the microSD card or may overwrite files. Back up any important footage before updating.
Only from the manufacturer's official website or official support channels. Avoid third‑party downloads to reduce the risk of installing the wrong or unsafe file.
