When you rely on your dash cam for your protection and peace of mind, a sd card not working in dash cam can feel stressful. Your camera cannot save clips or record anything if the card has a problem. Many drivers feel worried when the dash cam says "no SD card" or simply stops working after a trip. You may worry about losing important videos. You do not need to give up on your camera. You can fix most SD card problems at home with a few simple steps.
You expect your dash cam to work in any situation, but you may not know how much work the SD card does. When your camera is on, it writes video files again and again---often all day. The camera deletes old videos and writes new ones as soon as the card is full. This cycle never stops while the device is on.
You often see signs when your SD card is not working in your dash cam. You might notice a "No SD card detected" message even when the card is in the camera. Your camera could ask you to format the card again and again.
You might see that your dash cam cannot save any videos or old files do not play. If your dash cam freezes, restarts itself or seems to forget saving videos, your card could be at fault. Watching for these clues will help you find the sd card not working in dash cam problem before you lose footage.
You want to keep your camera working, so it is good to know what can cause the card to stop.
Your dash cam needs an SD card that comes in the right format. If you use a card with the wrong format, your camera will show the sd card not working in dash cam message. Most dash cams read FAT32 or exFAT formats only. If you buy a card for your other camera or your phone, it could be in another format.
Your dash cam wants a card that fits its rules for speed and space. If your SD card is too slow or too big for your camera, the system might not record video or could skip parts. Not all SD cards with a large number or a cheap price will work. Your camera could stop recording or the files may look broken.
You want your card to connect well inside the camera slot. If you do not push the SD card all the way in or if the contacts are dirty, your dash cam might not detect the card. Dust, oil and dirt on those gold strips can keep your camera from reading or writing to the SD card. When your dash cam says "No card detected," you should check if the card is in tight and if the contacts look clean.
Your dash cam writes and erases files many times a day. This can make old SD cards wear out. The card then cannot save your new files. Damaged parts inside the card can make videos unreadable or your camera may refuse to write any more. If you use the same card for a long time, you might notice the sd card not working in dash cam more as days pass.
Your dash cam relies on built-in software, also called firmware, to communicate with the SD card. If the firmware is old, it might not work well with new cards or certain sizes. Your device may stop recognizing your card, even if the card itself is fine. Manufacturers update their dash cam software for better SD card support, so updating your camera can help fix some SD card problems.
Sometimes, your SD card has extra files left by your phone, camera or computer. These extra files can confuse your dash cam when it tries to find and save new videos. Your camera wants a clean card with nothing but its own files.
Cause of Failure |
Main Problem You Notice |
How Bad It Is |
Wrong Format |
"Format SD Card" comes up a lot |
High |
Specs Wrong |
Video stops or skips often |
Medium |
Dirty Contacts |
"No Card Detected" shows |
High |
Card is Worn |
Cannot play back saved clips |
High |
Old Firmware |
Brand new card not recognized |
Medium |
Extra Files |
Card looks full, even when you just emptied it |
Low |
It helps to have a clear path when you check your SD card.
After powering down, remove the card gently and push it firmly back into the slot. Listen or feel for a click. This can fix small contact problems. A good connection stops errors with the sd card not working in dash cam message and helps your dash camera reset.
Take a look at what is written on your SD card. Read your dash cam manual. Check that the card isn't too big or too slow. It often says "Class 10" or another speed on the label. Choose only the speeds and sizes that are in your manual.
Take the card out and put it in the card reader on your computer. The card is probably still good if your computer can find it and you can open the files on it. You might need to get a new card for your camera if your computer can't see it.
Take the card out and hold it up to a bright light to see the gold contacts. Use a soft cloth or an eraser to clean them up if they look dirty or cloudy. Get rid of any dust in the slot. Cleaning your dash cam makes it easier for it to talk to your SD card.
You can fix most problems with your SD card yourself, without having to pay for repairs.
Find the format option in the menu for your dash cam. Setting the right file system for saving videos happens in the camera, not on a computer. A quick format deletes old files and makes room for your dash cam.
Read more: How to Format a Micro SD Card?
For the most up-to-date firmware for your model, go to the manufacturer's website. Follow their steps to download and update your device. New firmware makes your camera work with more cards and fix a lot of "not working" problems.
If neither of the steps above works, get a new High Endurance card. These cards are made to record a lot of data all day long. Choose the size and speed from the manual. Your dash cam can record and save videos for much longer with a new high-endurance card.
Your Problem |
Simple Solution |
How Hard |
Wrong format |
Format inside dash cam menu |
Easy |
Card is worn out |
Replace with high endurance card |
Medium |
Old software |
Update firmware |
Medium |
Dirty contacts |
Wipe contacts gently |
Easy |
Poor connection |
Push card back in firmly |
Easy |
Good habits keep your SD card and your dash cam working for many years.
You should format your camera's SD card every two to four weeks. This quick step stops old files from making things slower or causing problems. It also gives your dash cam a new beginning. If you don't do this step, problems like the sd card not working in the dash cam will happen more often.
Use only a card that works with your dash cam. Big or expensive cards aren't always better. Choose cards that say "Class 10" or "U3" for video that is smooth and clear. This match will give you the best results every time you drive.
A lot of cheap cards you can find online are fake and won't work. Buy from a well-known store or brand. A real card keeps your dash cam safe and ready to go.
Check the SD card and watch your videos every month. Make sure you have every moment you need. Check that the loop function works and that your dash cam saves each video clearly.
The SD card in your dash cam has to work right for it to help you drive with more confidence. There are many reasons why the common sd card not working in dash cam error happens, such as formatting mistakes or cards that have been used too much. You learned how to spot the warning signs early, check your card, and follow clear steps to fix each problem.
Your card could be the wrong type, the wrong format, have dirty contacts, or just be old and worn out.
You can format your card with the dash cam settings, gently clean the card contacts, or update the software on your dash cam.
Most Wolfbox dash cams work best with a 64GB or 128GB high endurance card. This gives you a good balance.
To give your dash cam a fresh start, go to its settings and look for the "Format SD Card" option.
