Modern trucks are equipped with more technology than ever, and safety tools are becoming a key part of the driving experience. Many drivers and fleet managers now rely on dash cameras to protect themselves on the road, record incidents, and improve driving safety. So a common question is: do trucks have dash cameras?
In this guide, you will learn how common dash cams are in the trucking industry, what the law says about using them, why fleets and drivers are installing them, the types of cameras available, and the key features to look for when choosing a reliable truck dash cam.
There is currently no federal law requiring every commercial truck to use a dash cam. However, adoption across the trucking industry is growing quickly. Many fleets now install dash cameras to improve safety and document incidents on the road.
According to the American Transportation Research Institute, driver-facing camera footage can help exonerate truck drivers in more than half of insurance claims and nearly half of litigation cases when video is available. This highlights the growing value of video evidence in commercial trucking. As a result, many fleets are adopting video-based safety systems to monitor driver behavior, protect drivers, and support training programs.
Dash cams are not only used by commercial fleets. They are also becoming popular among pickup truck owners and off-road enthusiasts. Drivers who take modified trucks on trails or overlanding trips often install dash cams to record their adventures and capture scenic routes. The camera view can also help drivers check blind spots around larger vehicles, especially when driving on narrow trails or crowded roads.
As the technology improves and prices become more affordable, dash cams are becoming a common upgrade for both commercial trucks and personal pickup vehicles.
Understanding the rules about dash cameras in trucks may seem tricky, but you can break it down step by step. You should know which rules you must follow and which things are simply smart choices. The laws are quite clear once you look at them.
You do not have to put a dash cam in your truck because the Federal Motor Carrier Safety Administration (FMCSA) does not make it a rule. If you decide to use a camera, you still need to follow the FMCSA regulation 393.60, which says your dash cam cannot block your view of the road.
Even though you do not have to install a dash camera, recording what happens inside your cab, like audio or video, is a separate issue. This depends on the laws in each state. Many states want you to get permission from anyone who is being recorded in the cab. This is even more important when it comes to recording sound.
If you run a fleet, you need to let drivers know when cameras are in their trucks. It is smart to have rules about dash cameras that everyone can see. If you drive your own truck, you should check the laws in any state where you work. This can help you avoid legal trouble in the future.
You and other truckers, along with fleet managers, see real value in dash cameras. These cameras do much more than just record your drive.
When there is an accident involving a big truck, things can get confusing fast. Many times, you, as the truck driver, might get blamed even if it is not your fault. A dash camera gives you a clear video of what really happened. This means you have proof to show you did nothing wrong, which is very important for any truck driver.
Having a dash camera in your truck or fleet doesn't usually lower your insurance premium directly. But it can still help in important ways.
You can use dash cam footage as a great learning tool. When you watch your driving videos, you can see if you are following safe habits or making mistakes, like following too closely or not paying attention. With these recordings, you and your manager can talk about ways you can become a safer and more careful driver.
Your truck and what you carry are both valuable. A dash camera can keep an eye on your truck even when you are away. If someone tries to steal your cargo or damage your truck, your dash camera will record everything. This video can help police see what happened and find the people who did it.
Mirror dash cams let drivers see blind spots in real time on a 12-inch screen. This improves safety for truckers on highways and off-road enthusiasts navigating tight trails. It helps spot vehicles, pedestrians, or obstacles that traditional mirrors miss. Drivers can make safer lane changes, turns, and trail maneuvers. It also reduces accidents and protects both cargo and passengers.
You have many choices when it comes to dash cameras for your truck. Your choice depends on what you want and how much you want to spend.
A forward-facing dash cam is the simplest type you can choose for your truck. You place it on your windshield, and it records everything that happens in front of you as you drive. This camera helps you have proof if an accident happens or if you need to show what happened on the road. Forward-facing cameras do not cost a lot and are simple to set up in your truck.
A dual-channel dash cam has two cameras. You get one that records what is happening in front of your truck and a second one that records inside your cab or behind your truck. This setup covers more angles, so you get better coverage of what happens. You can see what is going on in your truck and also what is happening behind you.
You can pick a multi-channel system if you want the most coverage around your truck. These systems come with three, four, or more cameras. They watch the front, back, and each side of your truck. With this kind of setup, you get a full view all around your truck, so you do not have any blind spots.
Camera Type |
Description |
Price Range |
Forward-Facing |
Single camera records the road ahead. |
$60 - $200 |
Dual-Channel |
Records front and rear view, or front and interior. |
$150 - $400 |
Multi-Channel |
3+ cameras for a 360-degree view. |
$400 - $800+ |
You want a dash cam that is strong and has the right features for your job as a driver. Not all dash cams work the same way. Your dash camera should handle daily use and give you the features you need on the road.
You need your dash camera to record clear video. Look for a dash cam that can record at least 1080p Full HD. This helps you see important details like license plates even in tough light or bad weather. A wide-angle lens, about 140 degrees or more, lets you see everything happening on the road in front of your truck.
WOLFBOX dash cams give your truck sharp and clear video quality. You can choose models like Wolfbox G900TriPro or G900Pro that record in 4K for very crisp images.
A good truck dash cam should be able to record clearly in low-light conditions or at night. Look for cameras with infrared (IR) LEDs or advanced low-light sensors. This ensures you can capture license plates, road signs, and any incidents, even when it's dark or poorly lit. Night vision helps improve safety by giving you reliable footage during night drives, early mornings, or in tunnels. Some models also enhance contrast and reduce glare from headlights, so you get clear images without overexposure.
Loop recording helps your dash cam keep working without you doing anything extra. When your memory card fills up, the oldest videos get replaced with new ones. This way, your camera always records, and you do not have to worry about running out of space. You can count on your dash cam to keep recording everything you need.
A G-sensor helps your camera know if your truck has a sudden bump or crash. When this happens, the G-sensor locks the video file that shows the event. This locked video will not be erased, even when the camera keeps recording new clips over the old ones. This way, you always have the proof you need after an accident.
A GPS feature helps your dash camera show where your truck is and how fast you are going. When your dash camera records a video, it adds details about your location and speed. This helps you explain any events that happen while you drive. You can use this information to show your exact speed and where something occurred.
Some dash cameras can send your videos directly to a cloud account. This means that your important videos will stay safe even if you lose or break your camera or memory card. You can access your saved videos from any device, so you don't have to worry about losing proof when you need it.
Why It's Important for Your Truck |
High-Definition Video |
Captures clear details like license plates. |
Night Vision |
Records clearly in low-light and nighttime conditions. |
Loop Recording |
Continuously record your videos without manual effort. |
G-Sensor |
Automatically saves and protects collision footage. |
GPS Integration |
Adds location and speed data for context. |
Cloud Connectivity |
Backs up important video files securely. |
If you are comparing models, you can also check our guides on the Best Dash Cam for Semi Trucks and the Best Dash Cam for Pickup Trucks to see which options fit different types of drivers.
You might wonder, "Do truck drivers have cameras on their dashboards?" More truck drivers are putting dash cameras in their vehicles these days. There is no law that says you have to use a dash camera, but many fleets and drivers do now. If you want more safety and proof on the road, these cameras have gone from being extras to being standard parts of your truck.
Dash cameras give you strong protection from false claims, help lower your insurance costs, and make you safer while driving. As truck dash cam technology from WOLFBOX and other brands gets better and more affordable, you will likely see even more trucks with these cameras. Having a dash camera is now one of the best ways for you to protect yourself and make your time on the road safer.
Yes, many truck drivers and fleets now use dash cameras. You can use them for safety, to protect yourself from false claims, and to have proof if something goes wrong on the road.
No, you do not have to put a dash cam in your truck by law. The FMCSA does not ask for dash cameras in every commercial truck. Many drivers and companies choose to use them because they help keep you safe and are now a common choice.
Yes, you can use dash cam video as proof if there is a truck accident. This footage often helps show what really happened. Your dash camera can protect you and make your side clear if someone blames you for an accident.
Most dash cameras record while your truck is running. This is called loop recording. Many cameras also have a parking mode, so they can record if something happens while your truck is parked.
