Choosing the right emergency tool is about raw performance and total peace of mind.
| FEATURES | MegaVolt24 Air | NOCO GB40 |
| Peak Starting Current | ✔︎ 4000A Peak | 1000A Peak |
| Battery Capacity | ✔︎ 24,000 mAh / 88.8 Wh | ~6,500 mAh / 24 Wh |
| Gas Engine Rating | ✔︎ Up to 10.0L Gas | Up to 6.0L Gas |
| Diesel Engine Rating | ✔︎ Up to 10.0L Diesel | Up to 3.0L Diesel |
| Recharge Speed | ✔︎ Fast PD 65W Charging | Micro-USB Charging |
| Safety System | ✔︎ UltraSafe Spark-Proof Tech | ✔︎ UltraSafe Spark-Proof Tech |
| Price & Value | $139.99 (4x Power + Built-in Pump) | $99.95 (Basic Starter Only) |
| Conclusion | ★★★★★ | ★★★★☆ |
See how automotive creators and everyday drivers put the MegaVolt24 Air to the test in real-world roadside emergencies.
Capped at a -4°F to 122°F limit, with an official recommended max storage/operating temperature of just 104°F (40°C)—making hot summer trunk storage risky.
Engineered for a wider -4°F to 140°F (-20°C to 60°C) thermal threshold. Built to store safely and deliver full power even in extreme summer cabin heat.
Uses standard Micro-USB input—taking 3 to 6+ hours to fully recharge with no high-speed laptop output capability.
Features 65W Bidirectional PD Fast Charging—fully recharges in ~1.5 hours while doubling as a high-speed laptop & phone power bank.
Compact 24 Wh (~6,500 mAh) battery reserve, rated for up to 20 jump starts per charge on small to mid-size engines.
Commercial-grade 88.8 Wh (24,000 mAh) reserve—delivering up to 40 jump starts on 3.0L gas engines on a single charge.
Single-function jump starter only. Completely helpless when tire pressure drops or when you hit a roadside flat.
Integrated 160 PSI air compressor driven by a heavy-duty 25mm cylinder (up to 45L/Min airflow) to inflate tires in minutes.
Requires buying a separate air pump alongside the $99.95 battery booster, cluttering trunk space with multiple devices.
Integrates a 4000A booster and 160 PSI compressor into one sleek unit for $139.99, keeping your gear organized in one bag.
Real feedback from real drivers
Four reasons why drivers choose the MegaVolt24 Air for complete roadside security
Deliver 4000A peak output to instantly start up to 10.0L gas and 10.0L diesel engines effortlessly.
Fully recharges in 1.5–2 hours and doubles as a high-speed power bank for mobile devices.
25mm cylinder inflates tires from 29 to 36 PSI in just 60 seconds with real-time pressure monitoring.
Multi-protection smart clamps guard against spark, reverse polarity, over-current, and extreme heat.
Everything you want to know about MegaVolt24 Air
Upgrade from basic single-function boosters to the complete roadside security of the Wolfbox MegaVolt24 Air. Combining 4000A of raw cranking power with an integrated 160 PSI air compressor and PD 65W fast charging, it delivers heavy-duty protection that standard units simply can't match. Keep your vehicle powered, your tires inflated, and your family safe on every road trip.
GET WOLFBOX PROTECTION — $139.99
