While your Ford F-150 may start okay in the morning, it can begin to incur problems when left sitting long-term, if there’s a sudden temperature drop, or if you’re using accessories that have drained its battery. You’ll need to choose a jump starter that is the correct size for your pickup truck. The best jump starter for your Ford F-150 is one that is sized around your engine, starting conditions, and how much power headroom you need in reserve.
The WOLFBOX MegaVolt24 has a 4,000A peak current and a 24,000mAh internal battery, making it an ideal option for F-150 owners who want substantial power headroom. It is suitable for gasoline and diesel engines up to 10L, making it best suited for owners who want to purchase one jump starter that is compatible with a 5.0L V8 engine and other larger vehicles [1].
Which Size Jump Starter Does a Ford F-150 Need?
A high-capacity jump starter, like the WOLFBOX MegaVolt24, is the safest all-around choice for a Ford F-150 as the model’s engines range from the 2.7L EcoBoost V6 to the 5.0L V8. The MegaVolt24 offers substantial headroom for any of the Ford F-150 models, as it is designed with significantly more engine capacity coverage than the 5.0L V8 requires [1].
Choosing a larger jump starter offers extra reserve for F-150s with a smaller engine, such as the 2.7L and 3.5L EcoBoost models. It’s also suitable for owners who may want to use the same jump starter for multiple vehicles with a gasoline or diesel engine that’s up to 10L in size.
Why F-150 Owners Should Size a Jump Starter by Engine and Use Case
Engine displacement is one of the most important factors to consider when choosing a jump starter. It’s the total volume of air and fuel swept by an engine’s pistons during a complete cycle and is usually measured in litres or cubic centimetres [2].
However, there are other factors to consider when choosing a jump starter for your Ford F-150 that influence the starting demands on your vehicle. You’ll want to consider the battery condition, temperature, electrical load, how long the truck has been parked, and whether the vehicle is using any accessories that may have contributed to the battery drain [3]. Pro Tool Reviews reached a similar conclusion after testing the MegaVolt24 firsthand, noting that "it can also handle most full-size trucks, cars, and just about anything else you can think of" [6].
The WOLFBOX MegaVolt24 is designed for Ford F-150 owners who want a jump starter with excess starting capacity, rather than choosing a jumper starter with a smaller unit that solely appears to match their engine size without considering these other factors. If you drive a Ford F-150 with a smaller engine and want a more compact and lightweight jump starter, then the WOLFBOX MegaVolt24 may not be the best option for you.
Is a 4,000A Jump Start Too Much For an EcoBoost F-150?
The WOLFBOX MegaVolt24 does not necessarily provide too much power for an EcoBoost F-150 if you want to have significant starting headroom. It has a 4,000A peak current, with the “peak current” being the maximum current a jump starter can deliver during a short starting event, rather than its continuous output [4].
The main benefit of the MegaVolt24’s 4,000A peak current is that it offers reserve capacity, meaning the same jump starter could be used for other vehicles as well. It gives F-150 owners considerably more capacity than if they choose a jump starter based solely on their engine’s displacement number.
Why the 5.0L V8 is Best Suited to a Larger Jump Starter
The WOLFBOX MegaVolt24 is a natural fit for a 5.0L V8 Ford F-150 because it is built for vehicles with a much larger engine-capacity than a typical passenger car. The 5.0L V8 is the largest conventional gasoline engine offered in the current F-150 lineup.
A jump starter with a smaller capacity may seem like it suits the needs of a 5.0L V8 engine on paper, but your vehicle may need a larger capacity if there are other factors in play, like battery drain from added accessories. The MegaVolt24 is also a sensible investment for a F-150 owner who also has other trucks, SUVs, or vehicles that they may want to use the same jump starter for.
Independent testing backs that up. TechGearLab named the MegaVolt24 its Editors' Choice pick for "Best Overall Jump Starter," ranking it #2 of 13 units tested, and noted it's "powerful enough to jump start large pickups and SUVs but small enough to leave in your trunk"—in testing, it successfully restarted a fully drained SUV battery three times in a row using only 3% of its own charge each time [5].
WOLFBOX MegaVolt24: The Best Jump Starter for the Ford F-150
With its 4,000A peak current and 24,000mAH capacity, the MegaVolt24 is suitable for gasoline and diesel engines up to 10L, providing more than enough power for any model of the Ford F-150 pickup [1].
It can be used by F-150 owners with a 2.7L EcoBoost, 3.5L EcoBoost, or a 5.0L V8 engine. The WOLFBOX MegaVolt24 is best suited for drivers who want one high-capacity jump starter that they can use on their F-150 pickup truck and other vehicles with higher headroom [1].
Is 4,000A too much for a 2.7L EcoBoost F-150?
No, the WOLFBOX MegaVolt24 may provide more capacity than a 2.7L EcoBoost F-150 strictly needs, but the extra headroom may be useful in the future or for larger vehicles [1].
Does a bigger engine always need a higher-amp jump starter?
No, engine size is only one factor to consider when choosing a jump starter. Battery condition, temperature, and the vehicle’s electrical system will also determine the type of jump starter you’ll need to use.
Can the WOLFBOX MegaVolt24 replace a failing F-150 battery?
No, the WOLFBOX MegaVolt24 is an emergency starting device, and repeated battery failures should be investigated by a professional mechanic, rather than repeatedly jump-started.
Is the WOLFBOX MegaVolt24 powerful enough for a Ford F-150?
Yes, the WOLFBOX MegaVolt24 provides 4,000A of peak current and is suitable for gasoline and diesel engines up to 10L, making it powerful enough for a Ford F-150 [1].
What does 4,000A peak current mean?
4,000A peak current means that the WOLFBOX MegaVolt24 delivers up to 4,000 amps during a short starting event. Peak current is not the same as continuous output or a vehicle battery’s CCA rating [4].
[1] WOLFBOX MegaVolt24 4000A Jump Starter: https://wolfbox.com/products/wolfbox-megavolt24-jump-starter
[2] Chase - What Is Engine Displacement and Why Does It Matter? : https://www.chase.com/personal/auto/education/maintenance/what-is-engine-displacement-and-why-does-it-matter
[3] WOLFBOX - Best Jump Starter for Cold Weather and Outdoor Use: Temperature, Capacity, and What The Specs Don’t Say: https://wolfbox.com/blogs/jump-starter/best-jump-starter-for-cold-weather-and-outdoor-use-temperature-capacity-and-what-the-specs-dont-say
[4] WOLFBOX - Jump Starter Buying Guide: Peak Amps vs CCA, Lithium vs Lead Acid, and How to Size The Right Unit
https://wolfbox.com/blogs/jump-starter/jump-starter-buying-guide-peak-amps-vs-cca-lithium-vs-lead-acid-and-how-to-size-the-right-unit
[5] TechGearLab - WOLFBOX MegaVolt24 Jump Starter Review: https://www.techgearlab.com/reviews/tools/jump-starter/wolfbox-megavolt24
[6] Pro Tool Reviews - WOLFBOX MegaVolt 24 Jump Starter Review: https://www.protoolreviews.com/wolfbox-megavolt-24-jumpstarter-review/
