Best Jump Starter with Air Compressor: 'Car and Driver' Picks WOLFBOX MegaVolt 24Air
Almost every automotive enthusiast relies on online gear comparisons to find the best ones. But it's hard to know which glowing review to trust and which is just marketing copy in disguise. That's where you can count on 'Car and Driver,' a well-known name for automotive reviews, advice, and news.
Likewise, it covers the best jump starter with air compressor, where 'Car and Driver' included the Wolfbox MegaVolt 24Air in its "Best Tire Inflator and Jump-Starter Combo" roundup, published on August 25, 2026. [1] The roundup reviewed units featured in the publication's previous tests rather than conducting a new head-to-head test specifically for this roundup.
We'll walk through what earned MegaVolt 24Air that recognition, what reviewers said about using it, and where it fits if you're looking for the best portable jump starter with air compressor. You'll also get a clearer answer on 'what is the best jump starter with air compressor.'
Why Car and Driver's Recognition Matters for the Best Jump Starter with Air Compressor
'Car and Driver' is one of the most established automotive media outlets in North America. Its product testing carries a different weight than an online review. 'Car and Driver' has tested and reviewed vehicles and automotive gear for decades.
It has built a reputation for hands-on, real-world evaluation rather than recycled spec sheets. The editors test a category like portable tire inflators by bringing in multiple competing units and running them through identical conditions.
That makes a big difference compared with a blogger testing a specific brand's product at home. That's what makes third-party recognition from a publication like this useful for anyone comparing the best jump starter with an air compressor.
Who Is 'Car and Driver'? A Trusted Name in Automotive Testing
'Car and Driver' is a long-running American automotive magazine and website. It's widely known for road tests, buying guides, and gear reviews that lean on direct, hands-on evaluation.
The magazine's accessory testing extends beyond vehicles to the tools drivers keep in their trunks, including portable tire inflators and jump starters. [2]
How Car and Driver Tested Portable Tire Inflators and Jump Starters
'Car and Driver' gathered a "truckload" of top-selling portable inflators and combo units. Their team conducted tire inflation tests on the units side by side in the same garage under the same conditions.
It also means the MegaVolt 24Air wasn't judged in a vacuum. Instead, it was ranked against dedicated, single-purpose inflators from brands like Unchartered Supply, Stanley, Top Don, and Gekogear. [1]
Best Jump Starter with Air Compressor: WOLFBOX MegaVolt 24Air
'Car and Driver' pick for the category is the MegaVolt 24Air. It's a 4-in-1 device that combines jump-starting, tire inflation, phone charging, and emergency lighting into one unit.
Reviewers noted that the MegaVolt 24Air stands apart from single-purpose inflators. It folds a "powerful 24,000-mAh jump starter and two ports – one USB-C and one USB-A" into what would otherwise just be a tire inflator. [1]
That combination is exactly what best 4-in-1 jump starter with air compressor searches are looking for. There, one device replaces several separate tools in the trunk.
4-in-1 Design: Jump Starter, Tire Inflator, Power Bank, and Emergency Light
The MegaVolt 24Air's four functions cover the most common roadside situations drivers run into. That's the whole point of buying a combo device instead of having four separate gadgets.
  1. Jump Starter: It restarts a dead 12V battery without needing another vehicle, a stranger's cables, or a call for roadside assistance.
  2. Tire Inflator: It inflates a low or flat tire on the spot, without a detour to a gas station air pump that may or may not work.
  3. Power Bank: Charges a phone or tablet through USB-C or USB-A when you're away from an outlet, during a roadside situation.
  4. Emergency Light: It provides visibility at night, whether you're changing a tire on a dark shoulder or just need to see under the hood.
 4,000A Starting Power: Enough Muscle for Gas and Diesel Engines
A 4,000A peak rating puts the MegaVolt 24Air ahead of what most sedans and crossovers need. It also provides enough headroom for larger engines.
The peak current is enough to start gasoline and diesel engines up to 10.0 liters. [3] But peak amps don't tell the whole story. What starts an engine is sustained current delivered at the battery's temperature.
A unit needs enough headroom above a vehicle's requirement to perform reliably. The 4,000A rating gives most drivers meaningful margin, not a bare minimum. [4]
How to Match Peak Amps to Your Engine Size
Daily-driven cars and smaller crossovers are comfortably covered by 1,000 to 1,500 peak amps when paired with a compressor rated around 150 PSI. Meanwhile, larger diesel trucks and full-size SUVs call for a jump starter rated at 2,000 amps or higher to handle their bigger batteries reliably.
At 4,000A, the MegaVolt 24Air sits well above either threshold. That's why Wolfbox positions it for the widest coverage in its jump starter lineup. It spans everything from compact sedans to 10.0L diesel engines in one device without needing a different unit for each vehicle in the driveway. [3]
24,000mAh Battery: Power for Up to 40 Jump Starts
The MegaVolt 24Air runs on a 24,000mAh (88.8Wh) internal battery. Wolfbox rated it for up to 40 jump starts on a single charge, depending on vehicle type and battery condition.
That capacity is also what powers the unit's tire inflator and USB charging functions. So, a single charge realistically covers several roadside situations before it needs recharging. [4]
For context, that's enough reserve to jump-start a vehicle and top off a couple of low tires. You'll still have enough charge left to top up a phone before you're back in cell range.
WOLFBOX MegaVolt 24Air: At A Glance
Specification
What the Number Means
Peak Current
4,000A (covers gas and diesel engines up to 10.0L)
Battery
24,000mAh / 88.8Wh (rated for up to 40 jump starts per charge)
Air Compressor
45L/min motor, 160 PSI max (inflates a 37×12.5R17 pickup tire from 35 to 40 PSI in about 1 min 50 sec)
Charging Ports
USB-C and USB-A (doubles as a portable power bank)
Car and Driver Ranking
Named 'Best Tire Inflator and Jump-Starter Combo'
Fast Tire Inflation: How Quickly Can the MegaVolt 24Air Air Up a Tire?
Inflation speed is where a jump starter with a built-in compressor either earns its "4-in-1" label or falls short. It's one of those few areas where independent testing becomes more insightful.
The unit's 45L/min (160 PSI) motor can inflate a 37×12.5R17 pickup truck tire from 35 to 40 PSI in 1 minute 50 seconds / a 275/75R17 SUV tire in about 1 minute 40 seconds, and can bring a 195/65R15 car tire from 30 to 36 PSI in just 39 seconds. [3]
Manufacturer numbers are useful, but they're measured under the manufacturer's own conditions. That's why the tire-inflation testing conducted by 'Car and Driver' on the unit adds further confidence.
Real-World Inflation Speed from 'Car and Driver' Review
The MegaVolt 24Air held its own in inflation, according to the performance information referenced by Car and Driver. [1]
It also carries a full jump starter and power bank in the same housing. Landing in the top half of a field that includes purpose-built inflators is a solid result.
The technical claim is a useful reminder that a 4-in-1 device doesn't have to be the fastest tool in any one category. Still, it can be the smartest choice for a trunk with limited space.
What Did Car and Driver's Reviewers Like Most?
Beyond the raw numbers, the reviewers called out specific hands-on impressions related to daily use. They highlighted the MegaVolt 24Air's build quality and included accessories as standout points. [1]
Solid Construction and Tactile Buttons
The review noted the unit's "sturdy build and tactile buttons" as a clear bonus. It's the kind of hands-on detail that only shows up after someone has actually held and operated a device repeatedly.
A Carrying Case Built for the Trunk
Reviewers also pointed out that the MegaVolt 24Air comes "paired with its own carrying case." They called the overall package highly likable because of the "included carrying case."
Is the Best Portable Jump Starter with Air Compressor Worth Buying?
Independent, hands-on recognition from a publication like 'Car and Driver' is a green signal. However, it's worth understanding exactly what that recognition does and doesn't claim.
Being "Best Tire Inflator and Jump-Starter Combo" in a side-by-side test is third-party validation of the MegaVolt 24Air's performance and convenience. Nonetheless, the review doesn't guarantee it's the fastest or most powerful device in every competing category. [1]
Dedicated single-purpose inflators still outpaced it slightly on raw inflation speed. Testers noted the hose length, so it's worth going in with realistic expectations.
Many drivers want one device that reasonably covers a dead battery, a low tire, a dead phone, and a dark trunk, not four separate tools. That independent review and 4-in-1 practicality is what most portable jump starter with air compressor shoppers look for. [3] [4]
Pair those facts with a 4,000A rating that comfortably covers a compact sedan to a 10.0L diesel truck. It's easy to see why an outlet that tests dozens of devices a year picked it out.
1) What is the best jump starter with air compressor?
'Car and Driver' named the Wolfbox MegaVolt 24Air as the "Best Tire Inflator and Jump-Starter Combo" after testing comparable units. It gained that recognition for a 4-in-1 design and solid all-around performance.
2) What is the best portable jump starter with air compressor for SUVs and trucks?
The MegaVolt 24Air's 4,000A peak rating and 10.0L gas/diesel engine coverage give it enough headroom for most SUVs and light trucks. Its inflator is fast enough on larger tires for those vehicles.
3) What is the best 4-in-1 jump starter with air compressor?
The MegaVolt 24Air combines a jump starter, tire inflator, power bank, and emergency light in one unit. It's the combination most "4-in-1" searches are looking for, backed by Car and Driver's hands-on testing.
4) How fast can the Wolfbox MegaVolt 24Air inflate a tire?
Wolfbox rates it at 1 minute 50 seconds for a 37×12.5R17 pickup truck tire and about 1 minute 40 seconds for a 275/75R17 SUV tire, both going from 35 to 40 PSI. A 195/65R15 car tire airs up from 30 to 36 PSI in just 39 seconds. [3]
5) How many times can the MegaVolt 24Air jump-start a vehicle on one charge?
Wolfbox rates the 24,000mAh battery for up to 40 jump starts on a single charge. However, the exact number depends on the vehicle and battery condition.
6) Is 'Car and Driver's recognition the same as a paid endorsement?
No. 'Car and Driver' involved a physical comparison of the MegaVolt 24Air against multiple units under the same conditions. It's a different process from a sponsored review or manufacturer claim.
[1] Car and Driver: "Tested: Best Tire Inflator and Jump-Starter Combos" –https://www.caranddriver.com/car-accessories/g73453791/best-inflator-jump-starter-combo/
[2] Car and Driver: "About US" –https://www.caranddriver.com/about/a41711746/about-us-contact-information-masthead/
[3] Wolfbox: "4-in-1 Jump Starter with Air Compressor Tire Inflator — MegaVolt 24Air" –https://wolfbox.com/products/jump-starter-with-air-compressor-tire-inflator-wolfbox-megavolt-24air
[4] Wolfbox: "Best Jump Starter Prime Day Deals 2026: MegaVolt 24Air, MegaVolt 10Air, and the Value Tier Worth Your Money" –https://wolfbox.com/blogs/jump-starter-with-air-compressor/best-jump-starter-prime-day-deals-2026-megavolt-24air-megavolt-10air-and-the-value-tier-worth-your-money
Off-Road Tire Pressure: Jump Starter With Air Compressor Guide
Best Jump Starter With Air Compressor for a Diesel Truck: Big Engine, 35-Inch Tires
