WOLFBOX G840S Review 2026: Road & Track's Prime Day Pick, One Month In
Road & Track listed the WOLFBOX G840S in their Best Dash-Cam Deals for Prime Day 2026 as a highlighted pick — not a budget filler, not a runner-up.1 Car and Driver ran independent testing and gave it their Best Overall designation in the 2026 Best Backup Cameras evaluation.2 Two publications, two separate editorial processes, the same camera. This review covers 30 days of actual installation and use: where the G840S earns those endorsements and where it has real limitations worth knowing before you buy.
What the G840S Replaces — and What That Actually Means
The G840S installs over your existing rearview mirror using rubber straps. No drilling, no adhesive, no permanent modification.3 The 12-inch IPS touchscreen takes over the mirror's visual real estate and shows the rear camera feed live while you drive, while recording front and rear video simultaneously. If your car has a small or absent factory backup camera display, this gives you a 12-inch rear monitor as a side effect of installing a dash cam — which is why Car and Driver tested it in the backup camera category and gave it the top overall designation.2
That combination is unusual. Most dash cams are either recording devices or display devices. The G840S does both at the same time, which is why it appears in searches for mirror dash cams, backup cameras, and parking monitors simultaneously.
Specifications
Specification
G840S Detail
Display
Front recording
4K UHD (3840×2160)
Rear recording
1080P Full HD
WiFi
5. 8 GHz (WOLFBOX App for iOS and Android)
GPS
Built-in; speed, coordinates, and route embedded in footage
Parking mode
G-sensor triggered; requires WOLFBOX Hardwire Kit (sold separately)
Rubber strap mount — no drilling or adhesive required
Storage included
32 GB microSD card
Warranty
18 months
Source: WOLFBOX G840S official product page.3
Installation: 20 Minutes, One Tedious Cable Run
Fitting the unit on a midsize sedan took about 20 minutes. The rubber straps loop behind the existing mirror and tighten with a tensioning mechanism that stays put on highway vibration. The front camera is integrated into the mirror unit itself — nothing separate to mount on the windshield.
The rear camera is where the time goes. It mounts on the inside of the rear windshield and connects via a long cable routed along the headliner and down the A-pillar. WOLFBOX includes cable clips and adhesive brackets, and the process is tedious rather than technically difficult — plan for it. One physical note: the 12-inch screen extends slightly further toward the cabin than a standard mirror. Check your mirror-to-headliner clearance before purchasing, particularly in vehicles with low headliners or high-set sport seats.
Front Camera: What 4K Gets You in This Format
In daylight, the footage reads license plates at 30–40 feet while moving — the threshold that matters for insurance documentation. WDR processing keeps the road surface readable even in direct sunlight when the sky is overexposed. GPS-derived speed and coordinates are embedded in every clip's metadata and visible in the WOLFBOX GPS Player app.3
At night on lit city streets, the footage is usable and clearly timestamped with speed data. The G840S does not use the Sony IMX678 STARVIS 2 sensor found in the G900 Pro. In most urban and suburban driving that distinction does not matter. On unlit rural roads at speed, where that sensor gap becomes visible, the G900 Pro's IMX678 is the upgrade path.
Rear Camera and Display: The Part That Changes Daily Driving
The rear channel records at 1080P Full HD — adequate for documentation in daylight. The display experience during daily use is what separates this camera from a standard dash cam: reversing into a tight parking space happens while watching a 12-inch live feed, with reversing guidelines overlaid automatically when the gear shifts into reverse.3
Drivers who parallel park frequently, back into tight garages, or manage a trailer report this as the most-used feature day to day — more than the incident recording that is the product's nominal primary function.
Downloading Clips Without Removing the Card
The 5.8 GHz WiFi connects to the WOLFBOX app and transfers a one-minute 4K clip to your phone in approximately 15–30 seconds. The GPS Player replays your route on a map with speed overlay — the same data embedded in every clip. For an insurance claim or a police report, you can produce video showing exactly where the vehicle was and how fast it was traveling at the moment of the incident.3
Rear Night Performance: The Actual Limitation
At night in low-ambient conditions — unlit parking lots, dark highways — the rear footage softens noticeably. License plates beyond 20 feet are not reliably captured in detail. For a rear-end collision at speed the footage documents the event. For a slow parking lot scrape at night, the plate on the other vehicle may not be readable.
This is a real trade-off, not a minor footnote. The G840S rear camera prioritizes the display format and a lower price point over sensor quality. Buyers who drive primarily in lit urban environments will not notice this limitation in practice. Buyers who regularly drive unlit roads at night should consider the G900 Pro (OmniVision OS04J10 rear sensor, 2.5K resolution) instead.
G840S vs G900 Pro: When to Stay, When to Upgrade
Scenario
G840S
G900 Pro
Large display + backup view at mid-range price
Right choice
Higher cost, same display size
Rear night performance on dark roads
Rear sensor is the limitation
OmniVision OS04J10 rear — meaningful upgrade
Front sensor in Sony IMX678 STARVIS 2 tier
Does not have IMX678
IMX678 STARVIS 2 front (2.0 µm pixels)
Lease vehicle, reversible install required
Strap mount — fully reversible
Same strap mount — identical installation
Truck or tall SUV
Check 12-inch unit headliner clearance
Same size — same consideration applies
Q: Did Road & Track recommend the WOLFBOX G840S?
A: Yes. Road & Track listed the G840S in Best Dash-Cam Deals for Prime Day 2026 as a highlighted pick. Car and Driver independently named it Best Overall in their 2026 Best Backup Cameras evaluation.
Q: What resolution does the WOLFBOX G840S record at?
A: Front: 4K UHD (3840×2160). Rear: 1080P Full HD. GPS data — speed and coordinates — is embedded in every clip and viewable in the WOLFBOX GPS Player app.
Q: Does the G840S require drilling to install?
A: No. It uses rubber straps that loop around the existing rearview mirror. Installation is fully reversible with no adhesive and no vehicle modification — suitable for leased vehicles.
Q: Does the G840S show a backup camera view when reversing?
A: Yes. The 12-inch display automatically shows the rear camera live feed when the vehicle shifts into reverse, with reversing guidelines overlaid on screen.
Q: How does the G840S WiFi work for downloading clips?
A: The G840S uses 5.8 GHz WiFi to connect to the WOLFBOX App (iOS and Android). A one-minute 4K clip transfers to a phone in approximately 15–30 seconds without removing the SD card.
Q: What is the main limitation of the G840S rear camera at night?
A: In very low-light environments — unlit parking lots, dark highways — fine detail at distance may not be reliably captured. The G840S rear camera prioritizes the display format and price over sensor quality. Buyers who need strong rear night performance should consider the G900 Pro, which uses a OmniVision OS04J10 rear sensor at 2.5K resolution.
Q: What warranty does the WOLFBOX G840S include?
A: The WOLFBOX G840S includes an 18-month warranty.
1. Road and Track – Best Dash-Cam Deals for Prime Day 2026: https://www.roadandtrack.com/gear/g71482999/dash-cam-deals-prime-day-2026/
2. Car and Driver – Best Backup Cameras of 2026, Tested: https://www.caranddriver.com/car-accessories/g44411856/best-backup-cameras-tested/
3. WOLFBOX G840S Official Product Page: https://wolfbox.com/products/wolfbox-g840s-12-4k-mirror-dash-cam-2160p-full-hd-smart-rear-view-camera-mirror-dash-cam
4. Yahoo Autos – Prime Day Dash-Cam Deals 2026: https://autos.yahoo.com/deals-and-buying-guides/articles/dont-wait-prime-day-dash-141000003.html
5. Car and Driver – Amazon Big Spring Sale Dash Cam Deals 2026: https://www.caranddriver.com/car-accessories/g70759591/amazon-big-spring-sale-dash-cam-deals-2026/
6. WOLFBOX Blog – Best Backup Camera 2026: https://wolfbox.com/blogs/dash-cams/best-backup-camera
7. WOLFBOX Blog – Best Mirror Dash Cam 2026: https://wolfbox.com/blogs/dash-cams/best-mirror-dash-cam-in-2026-top-picks-full-buying-guide
  1. WOLFBOX G900Pro Official Product Page: https://wolfbox.com/products/wolfbox-2024-g900-pro-wifi-touch-screen-parking-monitoring-dash-cam-smart-mirror-with-starvis-678-sensor
Wolfbox vs Viofo, Vantrue, and Garmin: What Buyer Reviews Actually Show in 2026
Best Dash Cam Prime Day Deals 2026: What to Actually Buy and What to Skip
