If you are wondering about the best way to add a rear dash cam to your truck, you're in the right place. Making your truck safer with a camera is one of the smartest choices you can make. A rear dash cam lets you see what's happening behind your vehicle at all times. This is important for parking, reversing, and guarding your truck against theft or accidents.
You might ask if you can set up a dash cam for your truck. The answer is yes. Whether you have a pickup, box truck, or a semi-tractor, a rear dash cam can help keep you safe and records your journey.
However, installing a rear dash cam on a truck is slightly different from installing one in a standard passenger car. Because trucks are larger and structurally different, there are a few important factors you should consider before starting the installation. Below are the key challenges, and how to handle them properly.
Trucks are bigger than most cars. Your rear camera cable must reach from the back to the front, so a long cable is helpful for your dash cam to connect properly.
Your rear window might be small or something could block the view like a toolbox or cargo. For the best view, you might set up the camera outdoors on the truck bed or near the license plate.
Moving a cable from back to front is a longer project with a truck. Try keeping the wire neat by tucking it under panels and alongside the frame where it stays out of sight.
You get quite a few choices about where the camera goes on your truck. Some drivers mount the camera inside on the rear window, and others choose outside mounting for a clearer view.
A regular truck usually has a 12V power system. Some large trucks use a 24V setup. Most dash cams from Wolfbox work with both systems, so you can feel relaxed about your power options.
Once you're ready to start installing a dash cam on a pickup truck, having everything prepared makes a big difference.
Thinking about where to mount your rear camera is a big step. The right spot helps you get a clear picture for driving and for reviewing footage.
For the best results, aim for a camera view looking straight back and wide, with the road and cars behind you centered in the picture. Setting the camera to show the horizon near the center of your footage helps you keep everything in sight.
Choosing the right mounting position for your truck's rear dash cam affects visibility, durability, and installation difficulty.
A higher position provides a wider and longer viewing angle, making it ideal for highway driving. It's easier to install and better protected from rain, dust, and road debris since it's typically mounted inside the cabin. However, on pickup trucks with loaded truck beds, box trucks with interior cargo, or semi-trucks pulling trailers, cargo, toolboxes, or trailer structures may partially or completely block the rear window view.
Mounting near the license plate offers a clear, unobstructed view—especially important for pickup trucks that frequently carry cargo or commercial trucks with blocked rear windows. It also captures vehicles closer to the ground more clearly, which can help during reversing or tight maneuvers.
The downside is greater exposure to rain, mud, snow, and road debris. For exterior installation, a camera like the Wolfbox G900TriPro Bumper Version, rated at IP67, is ideal for heavy-duty or long-haul trucks operating in extreme weather. Its waterproof design and durable construction ensure maximum reliability, while careful cable sealing and routing remain essential to prevent moisture intrusion.
Placement Option |
Pros |
Cons |
Top of Rear Windshield |
Bottom of Rear Windshield |
The shape of your truck decides where your camera should go. A truck with a rear window like an SUV lets you mount the camera right on the inside glass. If you drive a pickup with a bed, you may want an external waterproof camera. Wolfbox often gives you this option in their dash cam kits. Setting your camera up on the tailgate or right by the license plate keeps your line of sight wide and clear, no matter what is in your truck.
Some places on your rear window won't hold your camera well or may block your view. Don't place the camera on the dotted black area at the edge of many truck windows, the mount will not stick for long. Stay away from the area where the rearview mirror points, and off the defrost wire lines on heated glass.
Now you are ready to put everything together.
Pick your camera spot first. Hold your camera in place to see how the road looks on your dash screen. If you like the view, clean that location. Get rid of dust, oil, or water with an alcohol wipe or some glass cleaner so the camera will stick well and won't fall off after a few weeks.
Take the cover off the adhesive backing. Press the mount down firmly for 30 seconds on the spot you cleaned. Clip the camera into the mount. Before you do anything with cables, connect both cameras to your Wolfbox dash cam system. Check the screen and see if the rear camera shows the view you want.
Moving the cable all the way from the camera at the back to the main unit at the front can take time, especially with a large pickup truck. Every few inches, tuck the cable into the headliner or a side trim. Use a trim tool to gently nudge wires into place. Run the cable down the door pillar or along the floor.
At the front of your truck, you will connect the cable to the port on the dash cam display or main camera. Plug in your power cable as well. If you are just testing, the 12V truck adapter is a fast way to power your system while you make sure all the footage looks right and mounts are strong.
Some Wolfbox dash cams change the screen view to the rear camera when you put your truck in reverse. To use this feature, connect the red wire from the rear camera's cable to your reverse light wire.
Next, you should look at your power options.
Many drivers use this simple method. Plug the adapter into your 12V socket and run the cord up to your dash cam. The dash cam powers up with your truck and turns off when you do. You won't need any wiring knowledge, so it is a fast, easy option that works for most people.
Hardwiring lets your dash cam record even when your truck is off and parked. This type of setup is better if you need parking mode or want extra peace of mind. The Wolfbox hardwire kit protects your truck battery with its safe voltage system and makes sure your dash cam never drains the truck's battery.
To do this job, have your hardwire kit and a circuit tester ready. Your manual tells you where your truck's fuse box is. Use your circuit tester to find a fuse with power all the time, and another with power only when the key is on. Connect each wire from the kit to the matching fuse.
You want to be sure every part works before heading out.
Turn your dash cam on. The screen should show the whole road behind your truck, and not be blocked by anything inside or outside.
If things look crooked or too high, gently turn the camera until you see the road straight and clear.
Your dash cam screen or the app will show an icon (often a red dot) telling you it's recording. Double-check this before you drive.
Take a quick video during the day and another at night, then replay it. You should be able to see plates and objects behind your truck easily.
If you use the 12V adapter for power, turn your truck on and off—a working dash cam switches on with the engine and off when you take the key out.
You've learned how to install a rear dash cam on a truck and put your safety first. Add a dash cam yourself and drive with more confidence. You get clear video and protection, whether you are moving or parked. With Wolfbox, your dash cam looks and works like a pro did the work.
Put your camera at the top-center inside the rear window or outside near the license plate for a full view behind your truck.
A rear dash cam can be mounted either at the top or the bottom, depending on your needs. Top mounts inside the rear window give a wider, long-distance view and are naturally protected from the weather. Bottom mounts near the license plate provide a clear, unobstructed view, especially when carrying cargo.
Set the camera so the view covers the whole road and is level. The horizon should be about halfway up the picture.
Yes. Waterproof cameras from Wolfbox work great here. Mount the rear camera on your tailgate or just above your license plate for a clear view.
