High-quality, clear images and videos are impossible unless your camera lens is clean. No matter which type of camera you have, DSLR, smartphone, or dash cam. If you have some kind of dirt, smudges, or scratches over the lens, it may distort your photos.
One of the main ways of making sure that every photograph or video is sharp, clear, and without distracting elements is to keep your lens free of smudges. This article will give you the reasons why cleaning your lenses is necessary.
We cannot imagine our lives without dash cams, which will keep drivers safe and present them with necessary evidence in case of accidents. But a dusty lens can seriously damage the work of a dash cam. It is important to keep the lens clean and to understand the consequences of not taking good care of the lens:
The lens of a dash cam gathers dust, watermarks, fingerprints, and other scratches altogether. These impurities hinder the visibility of clear and sharp footage by the camera.
Problems produced by dirty lenses are more generally noticeable when driving at night or in low sunlight.
It is not only important to clean your camera lens so that clarity is maintained, but also so that the integrity of the lens is maintained. The lens might also be damaged permanently due to extended immersion in dirt or water.
A good lens that is kept clean is fundamental in jerky-free footage. Nevertheless, the windshield of your dash cam is very prone to getting contaminated by several extrinsic and intrinsic circumstances. Here are some of the most obvious offending factors:
Dash cam operating in cars is always exposed to road dust and gravel, among other air particles. A particle of grain or a speck of dust only needs to touch the surface of the lenses and scratch them, and reduce the quality of the video.
When you clean and adjust your camera by touching the lens, you leave behind the oils that you can avoid getting on the lens during cleaning.
Rain droplets and splash marks may dry up on the lens, where they may leave mineral deposits and lines.
Grimemay also accumulate on your dash cam lens due to pollutants such as smog, vehicle exhaust fumes, and deposits of carbon.
The following are the tips that you should remember to clean your camera lens without damaging it:
To properly clean your camera lens without damaging it, consider these essential tools:
Most of us are tempted to take the nearest cleaning object, but certain surfaces may ruin your lens or leave a smudge on it. The following are the things to avoid:
By cleaning your dash cam lens properly, you can be sure that there is clear recording. These are the steps of safe and effective cleaning:
Pick up loose bits of dust and particles with a hand-held air blower. Do not use compressed air because it will cause damage to the lens or force foreign materials further into it. To remove the dust, a soft brush can assist in cleaning up any remaining particles.
Wet a microfiber cloth with distilled water or a lens cleaner. Make sure the fabric is not soaked in order not to damage internal elements. Do not use harsh chemicals: Do not clean with household cleaners, they are harsh chemicals that will remove the coating off the lens.
A circular movement is to be used in cleaning the lens, starting inside the lens and moving outward. This removes smudges without transferring them. Do not put pressure to avoid scratches or coating damage.
Leave the lens to dry in the air. Then, with an entirely dry microfiber cloth, you should give the lens a gentle polish to eliminate streaks. These steps will ensure your lens is clean yet usable, and it does not have any damage.
The following is how to carry out rear camera lens cleaning under such difficult conditions:
Tip: You should use a water repellent covering on the lens so that the moisture will not build up on it, e.g., snow and ice.
Tip: Put a lens cover that prevents rocks and debris from blocking the lens.
Tip: Clean the lens frequently to avoid the collection of salt. Particles can be minimized by using an anti-static lens cleaner.
These are the typical indicators showing that your dash cam lens probably needs cleaning:
When your dash cam footage is blurry or out of focus, then chances are your lens is dirty. The lens can also be blocked by small dusts or fingerprints therefore affecting the quality of your recordings.
Along with some moisture or condensation, they tend to cover the lens surface, resulting in foggy or hazy footage.
Another effect of a dirty lens is the distribution of uneven light in your recordings, which results in overexposure in some parts of the footage.
Here are some additional dos and don'ts to ensure that your dash cam lens can remain cleaner for longer use.
A clear dash cam lens is needed to have clear, reliable footage when you require it. The impurity of the lens might block the visibility and hinder the quality of significant evidence. By simply giving it the proper attention and care, you should make sure that your lens is in optimal condition.
Selecting a reliable brand like Wolfbox ensures that you get dash cams equipped with waterproofed lenses. These lenses will reduce the possibility of water stain formation, dust, and dirt accumulation on the lens, which will make cleaning the lens easy and your footage flawless.
It is recommended to clean your dash cam lens once every 2-4 weeks or even more regularly in case you travel in severe conditions.
Cleaning a camera lens, a dash cam is not recommended to be cleaned with alcohol wipes. The lens coating may be ruined on a long-term basis courtesy of the alcohol. To clean the lens safely, a microfiber cloth and a lens cleaning solution that is specially made to clean the camera lens should be used.
In case cleaning of your footage does not help it to be less blurry, the factors may include the damaged lens, bad focus settings, or a problem on the inner side of the camera. Look into the lens surface and see scratches, focus your dash cam, or even upgrade to newer firmware.
