Best Dash Cam for Uber Drivers: Full Guide for Safer Rides
If you drive for Uber, there are many things you have to take care of. You must keep your passengers safe and also protect yourself and for that, you must have the right things with you. Dash cam is one such thing that can help you avoid false claims, record everything that happens and keep yourself and your car safe every day. We will tell you why a dash cam is a good thing for Uber drivers and how you can pick the best one for you in this guide.
Why Uber Drivers Need a Dash Cam?
Protects You from False Claims
As an Uber driver, you might face situations where riders make false claims against you. But with a dash cam, you can record everything that is happening in your car. If a rider accuses you of taking the wrong route or behaving badly, the video will help you show the truth and protect you.
Provides Evidence in Accidents
Accidents can happen anytime when you're driving on the road. A dash cam will help you record everything before, during and after the accident and this video proof will help you show what happened. This will help you avoid being blamed for something you didn’t do which will help you to protect yourself in such situations.
Keeps You and Your Passengers Safe
People act better when they know they are being watched. When you have a dash cam in your car, it can make you and your passengers more likely to be careful and polite. It will also stop them from doing bad things and help stop crimes before they happen, which will make it a safer ride for everyone.
Helps with Insurance Claims
You might have to show proof of what happened during an accident if you ever need to make an insurance claim. A dash cam will help you with clear video proof that will tell the truth. This can help you get your claims processed faster, more easily and with less stress which can save you time and money.
Tracks Your Routes and Driving
If your dash cam has GPS, it can record your routes and speeds. This is helpful if a passenger complains about the route or the way the driver is acting. It will also help you be honest and keep a thorough record of your daily trips, so everything is clear and you have a record.
Peace of Mind on Every Drive
When you drive for Uber, you meet new people every day which can be strange at times. Having a dash cam will give you peace of mind because you know everything is being recorded. You will have video proof to back you up if something unexpected happens which makes every trip less stressful.
What Is the Best Dash Cam for Uber Drivers?
High Resolution
When you are getting a dash cam, you must make sure it can record in at least 1080p resolution. Higher resolutions like 2.5K or 4K are even better because they can help capture small details like license plates or faces more clearly. This is very helpful when you need proof of what happened during an accident or dispute.
Night Vision
As an Uber driver, you have to drive at night as well, so your good dash cam should perform well in low light areas. You should get a dash cam with clear night vision so you can still see important details like faces, cars or street signs in the dark. This will make sure your footage will be useful, day or night.
GPS Tracking
A dash cam that has GPS tracking can record the exact location and speed of your car. This feature is useful because it shows where you are and how fast you are going during any ride. In case of any issue, GPS data can help you back up your claims and help solve the problem.
Loop Recording
You don’t have to keep replacing memory cards with a dash cam that has loop recording. This mode will automatically delete older files to make space for new ones before the memory card becomes full. It will make sure that your camera records continuously without any extra effort from you.
What Kind of Dash Cam Is Best for Uber Drivers?
Single Channel Dash Cam (Front Only)
Pros
  • Simple and cheaper
  • Easy to install and use
  • Records the road ahead clearly
Cons
  • Does not show what happens inside the car
  • No view of rear accidents or rear-end hits
  • Limited coverage
Dual-Channel Dash Cam (Front and Rear)
Pros
  • It can record both the road ahead and behind
  • Useful for rear-end crashes
  • It can help you get better coverage than single channel
Cons
  • No video of what happens inside the cabin
  • Installation may take a bit longer
  • Slightly more expensive
3-Channel Dash Cam (Front, Rear and Cabin View)
Pros
  • Covers the front, rear and inside of the car
  • Best for rideshare drivers
  • Record passenger behavior
Cons
  • Higher price
  • Need a larger memory card
  • Installation can take more time
How Much Does a Good Dash Cam for Uber Drivers Cost?
The price of a dash cam depends on its functions and the quality of its video. You can get a simple dash cam with one lens for around 50$. If all you want is a front view, these work well. Dual Channel dash cams have views from both the front and the back can cost $120 – $300, which will give you a fuller video picture. It costs around $150 to $400 for a 3-channel dash cam that can record the front, back and inside of the car. You can feel safe in your car with these.
Dash Cams in Our Best Picks
Wolfbox G900 TriPro
4K front camera with rear and cabin views. This dash cam is perfect for all-day driving and full coverage.
Details
Resolution
4K + 2.5K + 1080p
GPS
Yes
Night Vision
Infrared
Price
$395.97
Screen
12-inch Touch
Redtiger F17Elite
This dash cam can record High-quality dash cam for full coverage. This camera can record during both day and night which makes it good for Uber drivers.
Details
Resolution
4K front, 1080p rear and inside
GPS
Yes
Night Vision
Yes
Price
$359.99
Special
Voice Control
Nexar Beam2
This dash cam records videos and saves them to the cloud so you can access them from anywhere.
Details
Resolution
1080p
GPS
Yes
Night Vision
Moderate
Price
$179.95
Storage
Cloud Backup
Legal Considerations
  • Passenger Consent: In some US states, you need to get permission from all riders before you can record sound. You should check the rules in your area to make sure you follow them and stay out of trouble with the law.
  • Video vs. Audio: It is fine to take video almost everywhere. But depending on where you live, you might need to get permission from your riders before you record their audio. Always check the rules in your area before buying a dashcam.
  • Display Notice: To keep people from getting confused or angry, put up a clear sign in your car that says there is a camera recording. By doing this, you can stay transparent and avoid conflicts.
  • Privacy Laws: Different states and countries have their own privacy rules. Some treat ride-share cars like private spaces, while others don’t. It’s important to know the specific rules for your location to stay compliant.
  • Uber's Policy: If you’re an Uber driver, make sure to register your dash cam in the Uber Driver app. This shows you’re using the camera responsibly and helps avoid any issues with Uber's policies.
How to Install and Set Up a Dash Cam for Uber Driving
You should clean your rearview mirror to make sure your camera mount gets proper adhesion. Place the front camera securely behind the rearview mirror.
  • If using a dual or 3-channel dash cam
  • Route the rear camera wire carefully to the back window.
  • Make sure the rear camera is positioned to capture the full view of the rear.
  • For a cabin camera (if applicable)
  • Adjust the cabin camera to aim at the back seats for optimal coverage.
  • Connect the dash cam
  • Plug it into your car’s power outlet for easy installation.
  • Else, hardwire the dash cam for a cleaner setup and to free up your power outlet.
  • Test the dash cam
  • Check the camera angles to ensure all areas are properly covered.
  • Confirm the dash cam is recording before your first drive.
A dash cam can make your life easier and safer as an Uber driver. You protect yourself from false claims, record accidents and stay more confident on every ride. From basic coverage to full 3-channel protection, Wolfbox has the perfect dash cam to fit your needs and budget, without compromising on quality. Take the next step today and stay ready for anything on the road.
Can I use a dash cam for Uber driving?
Yes, you can use a dash cam while driving for Uber. However, it’s important to follow the laws in your area about video and audio recording to avoid any issues.
What size memory card do I need for Uber dash cams?
A 128GB memory card is a good choice for a 3-channel dash cam. It gives you plenty of space to store hours of video without worrying about running out of storage.
Do Uber passengers need to know I’m recording?
In some places, you’re required to let your passengers know if you’re recording. To stay compliant, you can put a clear sign or sticker in your car to inform them.
Will a dash cam drain my car battery?
A dash cam won’t drain your car battery if it runs only when the engine is on. If you use parking mode, a hardwire kit with a fuse is a safer option for your battery.
Can I install a dash cam myself?
Yes, you can install a dash cam on your own as most dash cams come with simple instructions. Just take your time with the wires and follow the steps carefully.
