If you have ever downloaded footage from your dash cam, you probably know how slow the process can feel. It is extremely slow due to Wi-Fi connectivity problems, right? So, it is crucial to select a proper frequency range for your dash cam. It will allow you to make the process of downloading easier and ensure better quality in general.
Let us talk about all these issues from a technical perspective – there are 5 GHz and 2.4 GHz types of Wi-Fi. Why do they differ? What impact does it have on your device? Which one suits your needs best?
Before we start talking about dash cams, we need to know some things. Wi-Fi works on kinds of radio waves. There are two types of radio waves that Wi-Fi uses, and these are 2.4GHz and 5GHz. You can think of the 2.4GHz and the 5GHz like two roads that cars can drive on. When we talk about dash cams and Wi-Fi, it is good to remember that Wi-Fi uses these two types of radio waves: the 2.4GHz and the 5GHz.
The 2.4GHz road is like the road that has been around for a while. It can go far and get through walls and things that are in the way, but it gets crowded really fast. This is because almost everything that uses Wi-Fi, like baby monitors, microwaves, Bluetooth things, and even routers from people's houses, uses this road.
The 5GHz road is like the road that is faster. It does not go far and has trouble getting through things that are in the way, but it is really good because it can go much faster, and there are not as many other cars on it, so Wi-Fi devices, like dash cams, can work better on the 5GHz road.
2.4GHz |
5GHz |
Speed |
Up to ~600 Mbps |
Up to ~1,300 Mbps (Wi-Fi 5) |
Range |
Longer (up to ~150 ft indoors) |
Shorter (up to ~50 ft indoors) |
Interference |
High (crowded band) |
Low (less congested) |
Wall penetration |
Better |
Weaker |
Best for |
Long-range, low-bandwidth tasks |
Short-range, high-speed transfers |
Ideal dash cam use |
Background sync over distance |
Fast footage download nearby |
According to the Wi-Fi Alliance, modern Wi-Fi 6 devices are increasingly using both bands simultaneously for smarter, faster connections, a trend that is slowly making its way into consumer dash cam technology.
A dash cam with wifi uses wireless connectivity to let you connect your smartphone and pull footage without removing the SD card. This means the frequency your dash cam uses has a real impact on your daily experience.
Here is what each band means in practice for dash cam users:
With 2.4GHz:
You can connect to the car from a bit away which is really useful if you park your car and you want to sync footage from a few feet away through the wall of your garage.
Transfer speeds are not as fast so it will take a lot longer to download a 1-minute video clip that's in 4K.
The signal is not as stable in busy parking lots or cities where a lot of devices are using the 2.4GHz band and that can be a problem, for the car.
With 5GHz:
Transferring files is really fast now. For example, a big video file that takes 2 minutes to transfer on a 2.4GHz connection will only take 30 seconds on a 5GHz connection.
The 5GHz connection is better and more stable because it has fewer channels and fewer people using it, which means the connection is cleaner.
When you want to look at the footage from your dash cam, you need to be close to the camera, like inside your car or right next to it. That is usually what you do anyway when you want to review the footage from your dash cam.
It depends on how you use your dash cam.
If your main goal is quickly downloading a specific clip after an incident like a fender bender or a near-miss, then 5GHz is clearly the better choice. Speed matters when you are trying to get footage off quickly and share it.
If you prefer your dash cam to automatically sync footage to your phone or cloud in the background while you walk away from the car, 2.4GHz may be more reliable at slightly longer distances.
New and expensive dash cams can use both kinds of wifi or they just use the 5GHz kind. This is because when you need to get video from your dash cam, your phone is usually next to it.
When you are trying to decide if you should use the 5GHz or the 2.4GHz for your dash cam, think about these things that happen in life:
Situation A: You park your car in a city area you get out, and you want to get a video from your dash cam really fast. You should use the 5GHz because it is faster and there is less interference from other devices around you.
Situation B: You are farther away from your car or inside a building and want to access your dash cam footage from your phone. You should use 2.4GHz because it offers a stronger range and better wall penetration, making the connection more stable over longer distances.
Let us get specific about the difference between 2.4GHz and 5GHz. When you are working with high resolution footage the difference between 2.4GHz and 5GHz becomes really clear.
Today, dash cams usually record in 1080p, 2K, and 4K. These files are very big. One minute of 4K footage can be from 400MB to over 1GB, it just depends on the bitrate.
On a 2.4GHz connection, the speed you actually get in a car is usually 20 to 30 Mbps.. On a 5GHz connection, the speed can be 100 Mbps or more.
For a 500MB clip, this means the difference between waiting 3 minutes and waiting 40 seconds.
This difference is important when you are standing in a parking lot after an accident, trying to get the footage from your dash cam before you drive away.
The real difference in speed between 2.4GHz and 5GHz is big in places with a lot of interference like a busy parking lot or street. The difference between 2.4GHz and 5GHz matters a lot, in these situations.
Whether you are shopping for a new device or evaluating what you already have, here are the key things to check:
Dual-band support: The best dash cam models support both 2.4GHz and 5GHz, giving you flexibility.
App connectivity: A good companion app should let you select your preferred band and show live footage.
Transfer speed rating: Look for cameras that advertise fast file transfer, as this usually indicates 5GHz support.
If you are looking for a solid real-world example, the Wolfbox G900 Pro is a great place to start. It combines Wi-Fi connectivity with a touch screen display, parking monitoring, and a Sony STARVIS 678 sensor for sharp low-light footage. It is exactly the kind of camera that shows how much a well-implemented Wi-Fi setup can improve your daily experience behind the wheel.
Looking to explore your options more broadly? The Wolfbox dash cam page covers the full range of what is available. And if you want to compare models side by side and find what fits your needs, browsing the best dash cam collection is a great way to start narrowing things down.
Here is the bottom line when it comes to 5GHz Wi-Fi vs 2.4GHz Wi-Fi in dash cams:
5GHz gives you faster file transfers, less interference, and a more responsive app connection, ideal for pulling footage quickly from nearby.
2.4GHz offers better range and wall penetration, useful for passive syncing or connecting over longer distances.
Dual-band dash cams give you the best of both worlds and are worth the investment if Wi-Fi speed and reliability matter to you.
For most users, especially those who record in 2K or 4K, 5GHz is the smarter choice. The speed difference is real, the interference reduction is noticeable, and the trade-off in range simply does not matter much when your phone is usually right there with the car.
The key distinctions lie in the speed and distance that Wi-Fi signal covers. While 5 GHz Wi-Fi is faster, less susceptible to interference and requires less power, it works efficiently only within short-range distances. On the contrary, 2.4 GHz Wi-Fi operates further but is much slower than its alternative. Nevertheless, 5GHz is better suited for dashcams as it ensures fast video downloading.
There exist some types of dash cams that are capable of connecting to both Wi-Fi bands simultaneously. If this is not possible, you should look into your device's specifications in order to determine what kind of band it uses.
The Wi-Fi frequency does not affect how good the videos are that your dash cam records.. It does affect how fast you can download videos from your dash cam to your smartphone.
When you have a dash cam that connects via 2.4GHz, drop-outs will occur due to the number of signals being interfered with around the area. Consider using a dash cam capable of operating at 5GHz to help reduce disconnections and maintain stable connections in more crowded environments.
Yes, particularly when recording footage in 1080p, 2K, or 4K resolution. The faster and more reliable transfer of footage means you can access your dash cam videos sooner. This is especially important, for dash cams that record high quality videos, like 2K and 4K dash cams.
